Question about HP PSC 1610 All-In-One InkJet Printer
Why blinking orange light
Printer is on but orange light is blinking. I probably need driver ???
    Sergeant:
  • 208 Answers
Not knowing any other details this is the best answer I can give you
one of the se links should be able to help you
Support Search Results
Posted on Jun 16, 2015
  • Les Morrison
    Les Morrison Jun 16, 2015
    Not knowing any details this is best answer I can give you
    One of this links should be a good answer to your issue
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: THe orange light on the printer continues to blink after...
download drifer HP LaserJet 1160
Posted on Mar 19, 2009
Anonymous
  • 118 Answers
SOURCE: orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Posted on Apr 29, 2010
Hi, The orange light in my canon ip1600 printer is blinking 5 times and green light once alternatively. Please give me a solution to fix it. What is the reason behind this problem? Thanks.
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Jun 25, 2011 | Office Equipment & Supplies
Hello there wondering if you can help me My power light on my Canon ip2000 keeps flashing green/orange and the print queue stops and nothing is happening. I've powered the printer on/off Also have...
Usually means theres a paper jam or your out of paper or some problem is occurring. While that blinking orange is blinking press and hold it for about 5 seconds the printer should stop blinking orange and continue with the print. Also open up your printer to see if there are any documents that are in the print queue. Probably can delete those. Thats my guess as to whats wrong with the printer. Used to have one of those. Nice little printer remember 12 blacks for 12 bucks.
Dec 16, 2009 | Canon PIXMA iP2000 InkJet Printer
The printer flashes orange light five times, and green once
3. Release RESUME
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Printer ip3000 starts with green light. orange light blinks once and repeats green and orange. wont start.
dear your setting have been changed please its best solution is to remove the printer driver and then install again.
to remove the driver open control panel and double click add/remove program and then printer driver uninstall.
then install the printer driver again from CD .
i hope this problem is solve.
another method.....
delete all the que documents and then switch off printer.OR
change the usb cable or change the ports.
Apr 10, 2009 | Office Equipment & Supplies
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
The light blinks 12 times, and nothing will print
suggest you need a new set of printer drivers
remove old version first
go here for new ones
re install
Mar 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon bjc 240/orange light stays on
The blinking orange light could mean one or more of the following: -Home position error -Waste ink full error -Temperature sensor error -Printing position correction error -Cleaning error -Printer memory error I would probably clean the waste ink tank first. Make sure you unplug it first. Take the cartridge out and clean real good at the bottom.
Jul 01, 2007 | Canon BJC 240 InkJet Printer
HELP!
Hi taximom, Is the light alternating back and forth between green and orange (GR OR GR OR GR OR GR)? Or is there a pattern like (GR OR OR OR GR OR OR OR GR) or (GR OR OR OR OR OR OR OR OR GR OR OR OR OR OR OR OR OR GR) If it the first case (alternate back and forth) then I hate to be the bearer of bad news but it needs service. (and it's probably not worth fixing) If there is a pattern to the blinking let me know exactly how many times it goes orange and I can tell you what to do from there. The Dude
Nov 16, 2006 | Canon BJC S300 InkJet Printer
PRINTER LIGHTS BLINKING RED THEN GREEN
Either you have ran out of an ink, because some epsons wont run until you replace cartridge, you have a document pending a print, or you need to disconnect printer, uninstall drivers from Add/emove programmes. Re-install driver then re connect printer when prompted
Nov 10, 2006 | Epson Stylus Color 760 InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
80 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
