Westinghouse W4207 42 in. HD-Ready LCD TV Logo
Posted on May 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Westinghouse W4207 speaker has static. How do I fix it?
Only one speaker is noisy
Level 3:
Top Expert:
  • Westinghouse Master 76,851 Answers
  • Posted on May 31, 2015
Westinghouse Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986825
Points
237762
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Westinghouse lcd
If picture is alright, check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Dm605 s2 speakers have static noise
If the noise you hear comes from the tweeter or the midrange speakers, it means your amplifier is noisy; if the noise comes from the woofer, then the internal amplifier (it has its own) of the speaker is noisy. If both speakers are noisy, it is most probable that the "static noise" you hear comes from the external amplifier, which you will have to check or change.
How do I connect the Westinghouse W4207 to my cable box since there is no coaxial connector? What cables do I need?
Download the user manual to yoru W4207. It has all type of input connections, here I can see. Go to manuals' page [7] to get more details.
If you feel any difficulty in downloading the same, send your email address to me, and get a copy of it by return mail.
Was dusting television, must have hit a button because now there's no picture. We can hear the satellite and can change the channels but there's no picture. the menu screen says no input
Simply try removing from the wall Power and and then reconnect, this should reset anything that was done.
http://www.generalmanual.com/Monitors/Westinghouse-W4207-HD-Monitor.htm
Above is your user manual this may help sort it out if removing from the power to reset doesn't work.
Image burn on my w4207 its really bad when using my computer
sorry to teel you this but you will need a new panel that is not covered by any warranty
2answers
Hello. I am looking a power supply for my w4207.
Hi, hard set to get parts for, try shopjimmy.com I`ve had luck finding some from them, good luck, video-tek
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
