My washer model kenmore wont do anything but the light forward and reverse spins, its full of water and wet clothes, tried resetting it, wont drain or fill up, tried every setting
Re: My washer model kenmore wont do anything but the...
Hi Dee.
You may have a kinked drain hose or a problem with your pump check the link below section 3.3 (problems with these machines)
Good luck,
Crofter Free Online Washing Machine Repair Manuals
If your washer will not spin out all water and clothes are still wet, the drain pump might be clogged with debris or possibly faulty. There could be a foreign object that is stuck in the pump and inside the drain hose. ... Test to be sure the drain pump is working properly.
https://removeandreplace.com/2017/03/08/washing-machine-is-spinning-but-clothes-are-still-soaking-wet-what-to-check-to-fix/
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
some models reverse the moter to activate the pump .. some have a solonoid to engage the pump .. depends on what model you have ... if the motor runs but still it doesnt pump then look for a broken belt that drives the pump .. on some there is a little universal joint that sometimes breaks .. often the pump becomes clogged with coins and other debree .. you didnt say if the spin cycle started or not .. if it doesnt then you could have a bad door switch .. if that doesnt operate then the spin cycle wont start and it wont drain as well .. you can test for clogs by taking the drain hose out and placing it on the floor .. if a lot of water comes out then its not clogged .. if no water comes out then you have a clog .. (be prepaired for lots of water) .. even if water comes out there still could be a coin stoping rotation of the pump .. there is no reset on the pump, it is almost always run by the main motor ..
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not. need to know if it agitates or drains and just wont spin. if it agitates but no spin or drain, then you have a bad lid switch. if it wont agitate or spin, but will drain, then you have a broken drive coupling.
