SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at [email protected]
Thank you very much.
SOURCE: red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
SOURCE: Hi I have 1.5 ton samsung split AC. the problem is...
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
There's a redlight turned on in the inverter of my O General 1.5 ton AC. What might probably be the problem? Please guide.
PARTHEBAN Tamil
