Question about Roper RS22AQXKQ Side by Side Refrigerator
I want to remove cover over water / ice dispencer to clean behind it
2 Suggested Answers
6ya staff
SOURCE:
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: Ice maker will not make
Hello, wes
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Oct 31, 2011
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
No water to ice maker. water comes out of cup dispencer
This uses a dual water valve each with its on solenoid coil. Remove the black cover in back, locate valve and switch wires on the coils. If you now get water to the ice maker change the valve.
Nov 18, 2010 | Amana DRS2663B Side by Side Refrigerator
Door Ice dispencer Problem
First , remove the top freezer door hinge cover ( only held by 1 screw ) . Disconnect the plug there , to remove power to the door . Use a butter knife or flat head screw driver , and pry outward from the BOTTOM of the dispensor control plate . Disconnect the 3 plugs there and set aside . Remove the 3 or 4 screws holding the arm and cover in place , and slide out . Your problem , is probably a rusted coil and plunger , in the top right corner with 2 black wires going to it . The part # is WR62X10055 . Solenoid coil and plunger is the correct term for it . Cleaning will not work for long , only replacing will correct for a long period of time .
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water dispencer and ice dispencer stopped working
Make sure the water supply line is turned on (the valve probably is behind the fridge or under the sink ) also check if is kinked or damaged.
Aug 25, 2009 | Kenmore Freezers
How to remove water dispencer cover
you must start at the bottom prying the plastic off carfully with a flat head screw driver.
Phil
Jun 11, 2009 | Refrigerators
Water dispenser does not work
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
WATER DISPENCER DOES NOT WORK, YOU CAN HEART THE MOTOR GOING BUT
first thing to do is to remove the lower back panel behind the frige and disconet one of the water lines that goes to the top back of the frige and push the switch to get water with the line of. do that to the 2 lines one at to give you water back there. if none of the lines gives you water back there 100% that plastic valve needs replacing.
Dec 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Pouring water
Franny, there are two switches mounted to a module in the ice and water despensor. It sounds like one of the plastic retainers on either the levers or the module itself has broken and the water switch is being made. You will have to remove the outside cover to get at these switches and see what is causing it to remain on. To remove the cover there should be two slots at the bottom that a flat blade screw driver will fit in. Gently pry the cover outward and when it releases, lift up to remove completely. You will now be able to see the module holding the switches. If you think this might be too much of a job, turn the water off behind the refer, shut the ice-maker off by lifting the bailing arm and call a tech. Catriver...post back.
Aug 16, 2006 | Frigidaire FRS23KF7AB Side by Side...
Roper RS22AQXKQ Side by Side Refrigerator Logo
75 people viewed this question
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
