Error message paper is jammed, clear the paper but there is no paper stuck, how do I get rid of the "error" message
SOURCE: Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: Printer says clear paper jam then press reset
Could there possibly be:
A) Paper jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the cover. Power on.
B) Foreign objects in printer: Power Off. Open the paper support and confirm that there is no foreign material in the auto sheet feeder. (If so, remove it by hand or with tweezers). Open the front cover and confirm that there is no foreign material in the unit. Avoid touching the inner workings of the machine.
C) Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on.
If all of these suggestions fail, your iP1600 may require repair service. Please note: With the suggested retail price of $29.99 USD, repair does not seem cost effective - you could just go out and purchase a new printer.
SOURCE: Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
