SOURCE: Installing developer
If you give me more details regarding the exact model, I may be able to link you to a service manual.
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
SOURCE: changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
SOURCE: What is the difference between the toner and
Toner provides the color, Developer consists of magnetic particles that carry the color on the outside of the developer drum, which is magnetic. Some developer is lost on each copy, although most stays in the developer unit. When you run low on developer, your image gets lighter and lighter, until the machine reports an error because it can no longer self calibrate. One change of developer suffices for many changes of toner. There is a procedure involving various actions and codes to flush the developer material out and load new developer in. This is not difficult, but there are a couple of reasons you might not want to do it if you are unsure why or if you should. First, developer for these estudio copiers, is very expensive. Second, unless you know how many copies have been made on the existing developer, you might change the developer, and fail to correct the problem. There are related service items, involving the cleaning blades, and seals, servicing charging grids, corona wire, and general cleaning of the 4 developer units and opc drums. Including dusting with zinc sterate, etc., etc. Its hard to know where to begin or where to stop. If you really want to know all about it, order a manual from any of a variety of on-line sources. Good luck
Testimonial: "Thank you very much. Now at least we know we need to get a technician. I just hate bringing one in to push one button!"
