When the shutter assembly fails all you can do is to set the camera to manual exposure, select the "B" shutter speed, and with the lens off and the back open, fire the shutter. In the B setting the shutter will remain open as long as you hold the shutter button, allowing you to see if there's an obvious obstruction.
If there's nothing obvious, then the shutter assembly must be replaced and as it's an uneconomical repair on that model your camera effectively becomes a spares donor.
You can get similar models very cheaply on auction websites or even for nothing at all on sites like FreeCycle and Freegle as they're effectively worthless, even in good working order.
Ok, I'll break it down for you. Look down on top of the camera. On the right hand side, there is the shutter button. Just to the left of the shutter button is a small lever. It is between the shutter button and the camera...but it's part of the shutter button. Move the lever to turn it on and off.
The problem could lie in the meter/speed dial unit or in the shutter itself. New parts are no longer available for that model. You may be able to find a good one on one of the auction sites or even Craigslist. A good used one would be less than a repair even if parts were on hand.
I also dropped my Fuji F30.
The half-press of the shutter didn't work anymore.
I bought a triwing / triblade screwdriver (about 5 euros) to open the case.
The flatcable running from the knobs on top of the F30 to the main print was a bit loose. After reconnecting it, the shutter button was fully functional again.
It seems that from the backside the most 3 three wires in the flatcable are for the shutter, so if your cable is also a bit loose, this might solve the problem.
NB Remember to only open the backside of the casing, there is no need to open the lens-side. Opening and closing the backside is really easy and could be done by anyone with the right tools. (read screwdrivers...)
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons :
1) defective switch.
2) defective flex cable.
3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
