Genie Garage Door. SilentMax 1000 3/4 HP Comparable Belt Drive Garage Logo
t
topper moet Posted on Jun 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wall button worked for awhile, now will not. Have tried a replacement, it does not work either. hat can I check?
Robert Plante
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 177 Answers
  • Posted on Jun 07, 2015
Robert Plante
Expert
Level 2:
Cheetah:
Answers
177
Questions
Helped
53994
Points
431
Touch the pair of wires that go directly back to the garage door opener together. If the garage door closes, than the wall switch is the problem. If the garage does not close when the two wires are touched together, than the problem is with the garage door opener. Please check to make sure that the opener is plugged-in and getting power to it also.
Unable to scan or copy. Getting "please wait awhile" notice
First try shutting down the printer using the off button. Then turn it back on. If this doesn't work then abruptly turn it off by pulling the plug from the wall and plug back in to the wall socket and turn on the printer.
I have a genie blue max that is about 20 years old and the red light on the eye will not come on, what would cause this, I have tried to line up the eyes to get it to come on but I hat doesn't work ei
check both wires from light beam box to the opener -- check for breaks or cuts or disconnects -- inspect closely. if you still have problem - replace the faulty beam unit - I do not believe you can replace just the laser bulb
Three men are facing a wall in single file. The furthest is #3 and he can see #2 and #1's heads. The man in the middle, #2, can only see #1's head. The closest to the wall, #1, cannot see...
#1 says he has a blue hat.
If #3 sees two red hats then he knows he has a blue hat. Since he says he does not know the color of his hat, #1 and #2 do not both have red hats. They may both have blue hats, or one a blue hat and the other a red hat.
If #2 sees a red hat then he knows his hat is blue since #3 did not see two red hats. Since he says he does not know the color of his hat, #1 must have a blue hat.
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
1999 chrysler sebring convertible jxi code p1495 intermittant shut off while driving. Replaced fuel pump and filter, distributor, spark plugs and wire. Was advised by ZJLimited to remove connector from the...
replacing the fuel pump relay is one thing but what about the (ASD auto-shut down) relay
additionally...
  • what engine size?
  • what transmission?
  • any codes?
  • does the pump run KOEO?
  • Do you have spark?
  • What is the cranking speed?
you may find faster service by subscribing to a "live chat" since there are so many questions and variables in your concern
WAS WORKING FINE FOR 2 YEARS. ALL OF THE SUDDEN I GET THE BLACK SCREEN. I WAS ABLE TO GET IT BACK ON AND DID A COMPLETE RECOVERY. IT STAYED ON FOR ABOUT20 MINUTES AND THEN AN ERROR MESSAGE ''DISPLAY...
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
hat will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Restart!.
Cordless phone went dead
leave batt out for a long period of time,then replace
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
5helpful
2answers
Heater only works on the 5th setting
I hat the same problem last week it was the blower motor resistor. Picked one up at Auto Zone but they are tricky to replace since it is on the passanger side up against the fire-wall.
Top Genie Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Genie Home Expert? Answer questions, earn points and help others
