Samsung WF328AA Front Load Washer Logo
Jennifer Nolan Posted on Jun 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does F21 mean on a Samsung Washing machine?
Jorgie the appliance guy
Level 3:
Top Expert:
  • Samsung Master 5,639 Answers
  • Posted on Jun 12, 2015
Samsung Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1521786
Points
32630
INDICATES A DRAIN ISSUE PERHAPS A CLOGGED WATER
PUMP OR HOSES ETC
what does F21 mean on a Samsung Washing machine? - f21-mean-samsung-washing-machine-dn3wi03dqy3vjnwbm4uf5us1-3-0.jpg
what does F21 mean on a Samsung Washing machine? - f21-mean-samsung-washing-machine-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg3wi03dqy3vjnwbm4uf5us1-3-9.jpg" alt="f21-mean-samsung-washing-machine-dn3wi03dqy3vwhat does F21 mean on a Samsung Washing machine? - f21-mean-samsung-washing-machine-dn3wi03dqy3vjnwbm4uf5us1-3-14.jpgploads/images/f21-mean-samsung-washing-machine-dn3wi03dqy3vjnwbm4uf5us1-3-14.jpg"what does F21 mean on a Samsung Washing machine? - f21-mean-samsung-washing-machine-dn3wi03dqy3vjnwbm4uf5us1-3-20.jpg14.jpg" class="h_mi" />
Natalia Keller
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Jun 07, 2015
Natalia Keller
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
5003
Points
12
It usually means that it's draining to slow. check the drain hose for kinks or blockage. if you have excessive suds it will block it from draining too. you can pull out your drain hose from the wall and let it drain into a pan. if any of this doesn't work then you might want to check the pump. The pump is usually hard to kill but if it has a lot of dirt in it, it will compromise it's function. Often just cleaning it is the solution. Cleaning is very easy. the pump is either located in a trap door in the front bottom or in the back floor level. Undo the hoses from the pump, unbolt and take it out. look for dirt or small items that may cause the pump to malfunction. clean it and re-install. if you don't use a high efficiency detergent be careful not to use an excessive amount. I use liquid detergent and I use half or less as instructed .
Whirlpool washer. Error code F21
If you see error code F21 on your Whirlpool washing machine, this refers to a water drain problem. The washer won't be able to finish the cycle and your laundry will be wet. This error code means draining is taking too long, and something is wrong with the water pumping.
How To Fix Whirlpool Washer Error Code F21? ' WHATT.ORG
Videos as well
https://www.google.com/search?q=Whirlpool+washer.+Error+code+F21
What does code f21 on a whirlpool duet mean?
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub.
Nov. 15, 2016
Whirlpool Washer Error Code F21 - DRAINING ERROR - How ...
Videos as well
https://www.google.com/search?q=code+f21+on+a+whirlpool+duet+mean
My washer whirlpool duet steam has a code of F 21 what does that mean
The digital screen come up with F21. How do I fix this
F21 means the washing machine has a “water draining issue”, meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub. If you have a front load washer then you need to locate the drain pump which is usually located on the bottom front of the machine. If you have a top load washer then you need to make sure the drain hose is not clogged or pinched. The drain hose is located in the back bottom of the washer
I have F21 on my machine, how can I fix it?
The F21 error is generally related to the drain of the washing machine (depending on the brand of your machine). Basically it means that the drain is clogged and the machine is taking too long to empty the water out.
Cleaning the drain is not for the queasy. You can find information on how to clean out the drain by visiting: http://www.kiwiservices.com/angela-says/fix-an-f21-code/
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
5helpful
Whats f21 mean?? a new belt??
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time, the belt is a non-factor.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry.
Regards,
Macmarkus :)
16helpful
What does f21 mean
an error code f21 means your machine may not be draining properly , it may have a kinked or bent hose that is keeping the water from flowing completely. check the back of the machine unkink it or replace it. good luck!
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
