Samsung WA456 top loader, two years old
Washing machines have springs to keep the tub centered. If one or more of those springs has come off or has broken, you'd get exactly those symptoms.
Testimonial: "Thank you! How would I check on the springs?"
SEE PICS FOR IDEAS WHAT TO CHECK FOR UR ISSUE
Samsung top load gets to final spin and bangs arou - gets-final-spin-bangs-around-like-crazy-dn3wi03dqy3vjnwbm4uf5us1-3-5.jpg03dqy3vjnwbm4uf5us1-3-5.jpg" alt="gets-final-spin-bangs-around-like-crazy-dn3wi03dqy3vSamsung top load gets to final spin and bangs arou - gets-final-spin-bangs-around-like-crazy-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg/images/gets-final-spin-bangs-around-like-crazy-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg" alt="Samsung top load gets to final spin and bangs arou - gets-final-spin-bangs-around-like-crazy-dn3wi03dqy3vjnwbm4uf5us1-3-14.jpg class="h_mi" />
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
My washer is doing the EXACT same thing. Repair man came and replaced the whole drum. Still doing the same thing. Did you ever find out what was wrong with yours?
