Question about Maytag Neptune MAH6500A Front Load Washer
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE
  • Maytag Master
  • 5,420 Answers
I would check the balance of machine by using a leveler and checking the bottom leg adjustment on all 4 legs then check the
suspension springs, counter weights, dampning straps etc.
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE - washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-0.jpg
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE - washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-5.jpg3wi03dqy3vjnwbm4uf5us1-3-5.jpg" alt="washer-moves-violently-gives-lr-code-dn3wi03dqMY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE - washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpgploads/images/washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg"MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE - washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-14.jpg9.jpg" class="h_mi" />
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE - washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-27.jpge-dn3wi03dqy3vjnwbm4uf5us1-3-20.jpg" alt="washer-moves-violently-gives-lr-code-dn3wi03dqy3vjnwbm4uf5us1-3-20.jpg" class="h_mi" />
Posted on Jun 11, 2015
  • Maytag Master
  • 12,731 Answers
Try this:
http://www.applianceblog.com/mainforums/threads/34721-Maytag-Neptune-Issues-SPIN-ISSUES-LR-CODE
6ya staff
SOURCE:
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
Gives an error code lr
The “Lr” = Locked Rotor: The machine has repeatedly tried to turn the motor.
I have seen this issue caused by a failed motor. I have seen a bad Control Board cause this issue and a bad Motor Controller cause this issue.
If the Lr error code happened in the Spin Cycle of the wash cycle it could be caused by seized Outer Tub bearings.
Without a known good Control Board and Motor Control board this could be difficult to troubleshoot.
Here is a link for the FAV6800A/FAV9800A Service Manual
May 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front lader washer maytag neptune
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Lr code keeps popping up on my neptune mah5500bww
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Crosley front load washer sometimes gives lr code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question &$^%^$T
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Neptune Washer
lr is a code for a locked rotor assy, on the motor itself, depending on age of machine you might have warr on the motor(part anyway) check your user guide and warr info. probably gonna need to install a "neptune repair kit" which includes new motor and new motor controller
Nov 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
246 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
