Question about Ac Delco AM-FM Radio Cassette
Have delco radio head unit model #1618995. has 7 wire plug 2 white wires on end one on end has small plug where do plug it too? has power checked with meter
    New Friend:
  • 30 Answers
Hi Steve,
I'm going to need a little more information. That looks like the serial number. I can't find any info on #1618995. What kind of car did it come out of? Sounds like some kind of Chevy. Is it an aftermarket radio? Delco is a bad choice, unless your replacing your radio with an other factory radio. What kind of car are you putting it in?
Let me know if your just trying to put an aftermarket stereo in, radio kits and wiring harnesses are available for most cars. Ray
Posted on Jun 12, 2015
6ya staff
SOURCE:
No electric output, how do I diagnose, capacitor, proper winding check etc.
Have you tried flashing your generator? Sometimes the magnets in the generator loose their polarity. Google and YouTube "flashing a generator"
HFLASHING the GEN
Sometimes the magnets lose their polarity. This worked on my brothers $1200 gen. Its worth a try. Good luck!
Check all wires/connections first, Then try this-
(Remove spark plug wire first!)
To flash the field on a small home use generator, get an ext. cord & cut off the female end of it & strip the wires & connect the wires to a 12 volt car or lawn tractor battery, & plug the male end of the cord, into the 120 A.C. side of the generator.
Make SURE that the black wire which is POS/HOT on an A.C. cord, gets connected to the RED/POS. side of the auto battery, & the white wire on A.C. cord gets connected to the BLK./NEG. side of the battery. If the ext. cord wires are not black & white, then the smaller prong of the plug is the POS./HOT
Plug the other end of the ext. cord into the generators 120 volt side (**remove spark plug wire**) & pull the starter cord 4-5 times, then remove the ext. cord, reconnect the spark plug wire, start the unit & plug something of 120 A.C. volts in to see if it works. Then let it run for about a half hour with 2 - 150 watt lights to help re-generate the unit.
Read more:http://www.doityourself.com/forum/outdoor-gasoline-power-equipment-small-engines/188605-recharging-generator-field.html#ixzz29QwjlAOWere's one way-
Dec 17, 2014 | Coleman Cable Coleman 5000w Progen...
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
How do I set the fusing unit correctly?
How to fix the Error: "Set the Fusing Unit correctly"
Ricoh Aficio SP C411DN & C410DN Color Laser Printers
Instructions:
1. There is a short Wire Jumper (color: black or white) on the inside of the main electrical connector of the Fuser Unit.
Note: These procedures can be done without removing the outer plastic housing of the Fuser Unit.
2. Press the side clip (or tab) and first pull the tab end of the large connector plug from the main housing of the Fuser Unit.
Warning: The connector plug wires are very short -- it extends a maximum of about 1 inch (or 2 cm) from the main housing of the Fuser Unit.
3. Use a small screwdriver and gently remove the small white connector that the Wire Jumper is plugged into.
Warning: Try to remember the correct orientation that this small connector is plug-in.
4. Use a small screwdriver (or a small flat blade) and gently raise the small tabs on the front of the small connector, while pulling gently on each end of the Wire Jumper.
Warning: Do not remove Wire Jumper forcefully by pulling.
5. Make sure that this Wire Jumper is plugged into the same pins as the one on the old Fuser Unit that is being replaced. There are only three pins that the jumper can plug into.
6. Reassembly the Fuser Unit by plugging in the two connector that were removed.
7. Replace the Fuser Unit into the Ricoh printer and secure properly.
8. Power on the printer -- it should start-up and go to the ready state without any errors.
9. The END.
Apr 26, 2010 | Ricoh 4506 Copier
1989 GMC Wiring Question
Red is power when switch is turned on. Orange is power all the time (runs the clock and radio presets when vehicle is turned off). Black is ground. The other wires are for the speakers and there should be 4 wires. You only have 3 remaining wire colors so there must be one missing. 2 wires per speaker=4 wires. Check again and add to this post.
Nov 15, 2009 | Car Audio & Video
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
I need to know which color wire is for what replacing radio
Normally you red wire is the battery+. Black is ground-. Yellow should be battery backup which should go to your ignition. You wil then have either two sets or four sets of wires depending if its a 2 or 4 channel radio. For instance,Brown, and brown with a white stripe- White and white with a black stripe and so forth. these will be you speaker wires. In every instance you wire with the stripe will be your negative.
May 01, 2009 | Car Audio & Video
Installing a DVD player in place of a Cassette deck
check out this website
www.mobileinformationlab.com
it is full of wiring diagram for vehicles.
did you happen to purchase the aftermarket wire harness that actually allows you to plug into the factory chassis harness? good luck let me know how you end up.
Mar 04, 2009 | Car Audio & Video
Wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Dec 13, 2008 | Car Audio & Video
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
308 people viewed this question
Top Ac Delco Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an Ac Delco Car Audio and Video Expert? Answer questions, earn points and help others
