Looking for spec sheet for fiat hitachi ex 135 excavator. year of manufacture is 2000. I am unable to find the corect spec sheet for this machine. the closect i can find on the hitachi website is for the ex 120-5
https://www.jdpower.com > rvs > terry > specs
Insure your 2002 Terry M-31G for just $125/year*. Leader in RV Insurance: Get the best rate and vocerates in the industry.*; Savings: We offer low rates and ...
F47 and F48. It looks like there are 12 relays in the links below but not marked. This link above has them marked and none for Windows, so check the fuses
The fiorino name have been used by Fiat since 1977. Please be specific on the model year.
Fiat also have 1.4L engine called FIRE. Used by so many models.
Jan 30, 2013 - 3 posts - 3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
go DownloadAManual.net and there is a manual listed for hitachi ex60-3 excavator service manual download
The dealer may be saying that it is a japan machine made under licence in china and is not covered by the hitachi warranty properly and because of that dealers are reluctant to work on them as they are considered inferior product
Unless you have a record of these fluids being changed in the past 18 months you should definitely change them. These fluids will degrade over time and need to be changed at appropriate intervals. You should also flush the engine radiator and cooling system and replace with new coolant to the manufacturer's specs unless this has been done in the past 18 months. Also ensure you change the engine oil and filter frequently (certainly more frequently than the manufacturer maximum interval specs which is based on optimum driving conditions which does not reflect reality.)
Brake fluid - every 2 years minimum Clutch fluid - every 2 1/2 years minimum PS fluid - every 3 years Coolant flush and change - every 2 years Engine oil - every 3500-4000 miles or 5 months minimum whichever is sooner Oil filter - every second oil change.
It's just a 2.5 SATA drive so any drive will more than likely do.....don't lock yourselft ito 80GB when there are 320, 500, etc out there. What is most important is the largest drive your system BIOS will recognize....which most ROMs can be flashed for compatability with newer larger drives.
Check with your Laptop Manufacturer Support Site to see the largest drive supported by your BIOS and if there are any updates.
uit egvalen
