White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP. http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/ or for Mitsubishi http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
