Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
SOURCE: my john deere lt 133 mower with a double blade
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
SOURCE: hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
SOURCE: Have a John Deere tractor LA145 Yesterday while
Either you need a seat switch or the reverse switch has failed.If the deck will engage while you are pushing down the forward pedal then the rio or reverse switch is not working or it's out of adjustment.If you can not get the deck to engage at all then the problem is likely the seat switch.
