Question about Samsung Washing Machines
How do I remove the drum from my machine to clean it it's a WA13V5 Samsung top loader washing machine
  • 3,961 Answers
This would be a major undertaking and requires special tools. Your washer has a "Clean Tub" cycle which you should use instead, as instructed, with a special purpose detergent such as (many alternatives are available)
http://www.affresh.com/our_products/affresh_washer_cleaner
You may need to do this twice over if the washer has not so been treated for a while.
If you are saying you have done this and it did not succeed, seek specialist advice from Samsung support.
Posted on Jun 16, 2015
6ya staff
SOURCE:
Anonymous
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Anonymous
  • 373 Answers
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
Anonymous
  • 3 Answers
SOURCE: Whirlpool top loader washing machine - agitator does not turn
If it does not drain, I'd check the water pump first (for an obstruction - I found a sock in my pump and that fixed my problem) ... see this video - the top is getting to the WM drive shaft (transmission), but it shows you how to remove the pump first: http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=related
If it does drain ... Is it just the TOP part of the agitator not working, or the whole thing (agitator is in 2 parts)? If just the TOP, you probably just need new "dogs" (agitator dogs). Check this out:
http://www.youtube.com/watch?v=V5wIN1J70-Y ... it shows you what to do.
If it is the whole agitator that is stuck, that video will show you how to remove it (remove a single bolt) and you can see if there is an obstruction keep the agitator from moving.
If there's no obstruction or the water pump isn't stuck, you might be looking at a new drive/transmission = expensive. Good luck
Posted on Jul 02, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: how do you remove agitator
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Posted on Aug 04, 2009
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
How do I replace the drain hose on the Samsung top loader WA13V5 machine please?
  • Open the clamp
  • Remove old hose
  • Install clamp on new hose end
  • Tighten clamp
Dec 11, 2017 | Samsung Washing Machines
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
Samsung wa13v5
The seals in the bottom of the drum where it connects to the gear box is going bad. Changing them out is something that you can do but it is not easy. You pull off the top cap on the agitator and then take off the nut and lift the agitator out, then you can see the seals.
Jan 19, 2014 | Washing Machines
How to remove a samsung 8kg top loader drum to pressure clean and remove black rubber like build up
No need to remove the drum. You can buy cleaning agents for the washing machine at the local supermarket. You have to actually run the machine in cleaner solution and you have to do this every 3 months at least.
Jan 16, 2014 | Samsung SW62ASP Top Load Washer
How do you take out the drum of a samsung Wa75b7pt top loader washing machine i want to clean it
Do not take drum out.
Run a wash without clothes in and put a mild bleach solution inside.
Feb 07, 2011 | Samsung Washing Machines
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
390 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
