If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
SOURCE: thin white static line at top of screen for some
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
SOURCE: I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
SOURCE: Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
SOURCE: black shadow on screen vizio 37 in lcd hdtv
There is a part inside
the TV that needs to be replaced. If the TV is under warranty—whether
the original warranty from the manufacture or an extended warranty
purchased with the TV—call the company providing the warranty
coverage and they will arrange to have your TV repaired at little, or
no cost to you.
Since some brands will
pay for your repair even if you're out of warranty, especially if
they've heard of your problem before and it's a known issue. You
should always contact the manufacture first for your full range of
options. If they're willing to fix the TV for free, or at a reduced
cost to you, let them!
If the TV is out of
warranty, and you have the experience and you know what you're doing,
you can fix the TV yourself. Purchase the service manual from the
manufacture to get started. However, if you've never done anything
like this type of repair before and you don't know where to start, I
suggest speaking with an experienced TV repair-person.
If you decide to pay for
out of warranty repair by a professional repair shop, the total cost
will likely be a minimum of $200 parts and labor. However, be warned
that the cost could be considerably higher.
I hope I've provided you
useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you today!
Please post a
comment if you need additional assistance so that I can help you
further.
Testimonial: "it was helpful thank you do you happen to know what this part is?"
