Why and how do I fix this issue?
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
SOURCE: lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
SOURCE: LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
SOURCE: Water and soap remains in the soap tray
You need to check for blockage in dispenser, remove completely and thoroughly clean every part of it.
Other possibility is not enough water pressure to take all powder down, check water pressure, filters in hoses if fitted..
Check hose from dispenser to drum for restriction.
Plz rate my solution.
Thanks.
