Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
A
Anonymous Posted on Jun 18, 2015
My Vizio e500i-b1 LEDtv went out last night. How can i tell if it's the main board or the tcon board that isn't functioning?
The backlight is working but i'm getting no picture or audio with a white screen
  • 2 more comments
  • Anonymous Jun 20, 2015
    i didn't see any swollen capacitors on the power board. How would i check the voltages?
  • Al Kizina Jun 20, 2015
    Did you try another input like DVD player to eliminate the tuner as the problem?
    No. All that comes on the screen is solid white. No menus interface or anything.
  • JC JC
    JC JC Aug 29, 2018
    Most likely the Tcon board is junk...
Al Kizina
Level 2:
Sergeant:
  • Expert 170 Answers
  • Posted on Jun 20, 2015
Al Kizina
Expert
Level 2:
Sergeant:
Answers
170
Questions
0
Helped
65561
Points
551
I would verify the voltages on the power supply board first because an improper voltage to a circuit board may make that board look bad.
Testimonial: "i didn't see any swollen capacitors on the power board. How would i check the voltages?"
    You need a DC voltmeter. This must be done with the power on, and I do not recommend doing this if you do not have experience working on powered equipment. You could get hurt or damage a good power supply board.
1helpful
Vizio E500i-b1 went dark, any ideas on what to check next?
You can change boards in your TV all day and it's most likely no going to fix this set. Have you ever had a set of miniature Christmas lights that seemed to work great then all a sudden none would light, either because a bulb burned out or fell out? There are 2 types of electrical circuit wirings, one is series the other parallel. In series like your LED backlights are wired in your TV there are about 8 button lamps per circuit that have a 24 volt DC supply serving each set as this TV has what's called local dimming, one of the lamps has opened up making that set not light up, the power supply has over voltage and over current protection for each supply if one lamp opens up they all go out and this is exactly what's happened in your TV, the power supply safety circuit is non discretional, if it detects an error it shuts down the entire backlight circuit giving you no backlights. As far as a break down on what fails 5% of the times it's the main board 5% its the power board and the other 90% of no backlight failures on this model TV comes from the backlights being bad. You can change just the one bad strip if you wish but it's advised to change them all. Good luck!
VIZIO E500i-B1 broke again a month after replacing the power board. Having similar issue
You might want to check the VIZIO website for help. Given how cheap even 4K UHD TV's are today, probably not worth fixing again. Unless under warranty, of course.
1helpful
Vizio tv model E500i-B1 I have sound but no video. If I unplug the TV over night the video will work again. Any idea of how to fix this problem?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I have a Vizio E500i-A1. I have backlights and sound but no picture. I have ordered and replaced the tcon, main board and power supply board. Still no picture. Any Idea what the problem is?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
My vizio will not turn on. The light on the bottom flashes on and off, but nothing on the screen. I replaced the main board. It worked for several days then went right back this issue.
Have just looked on you tube , I typed in fix for VIZIO E500i -B1 power off and a 2.24 minute video appeared . if that does not solve your problem type the product info and fault again and check the videos that pop up . hope this info is of use to you....
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
