The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
Hi, you need to perform a factory reset, follow these instructions:
Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
"Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
Use the volume buttons to move up and down through selection in this menu.
Using the volume down button, scroll down to "Wipe data/factory reset"
Tap Power hard key to select option.
Scroll down to select "Yes, delete all user data".
Tap the power button to select. Wiping and formatting data will take a few minutes.
You will return back to the Android recovery screen menu.
Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
So I guess nothing else to do but to get it to boot from a SD card with Android 4.1 on the SD Card, It appears your's is corrupted, there is a number of sites where you can download along with directions to make an Android boot card. Hope this gets you up and running.
ANDROID Tablet Freezes at Android startup screen For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button 2. When "VIMICRO" appears, Then Press & Hold the MENU button 3. The Android System Recovery <3e> Menu should appear 4. Scroll down using the Volume Key to "wipe data/factory reset" 5. Press HOME Button 6. Scroll down to "Yes - delete all user data" 7. Press the HOME Button At this point the system will do a recovery and hard start, and will be on "reboot system now 8.Press the HOME Button Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
