Initially, the whole screen was black, but I had sound. After some research, I replaced the Y-Sus board. Once I replaced the Y-Sus board, I now have a picture, but only on 2/3 of the screen. The remaining third of the screen is black.
Try adjusting the resolution depress the aspect button on your remote.
Terry
Testimonial: "Thanks for your response Terry. Not sure what the aspect button is; I looked and did not see it. The picture is actually cut off, meaning I do not see the right side of the picture. So, I am not getting the full picture which leads me to believe it is not the resolution. Do you have any other thoughts or do you still think it can be the resolution?"
SOURCE: vizio p50hdtv10a. Tv has sound
sounds like you needed to replace your video fuse before anything normally if you have video but no sound its an audio fuse and vica versa if for some reason both were out I would say your in need of a new power supply I would suggest replacing the fuse and if it still does not work contacting a service tech to run a diagnostic to see what exact part or maintenance you need
Robb
I do have picture, but just on the left 2/3 of the screen. I have sound as well.
4.17 Understanding Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
When watching a standard definition 4:3 aspect ratio (1.33:1 source)
the picture will fill the screen but will be stretched horizontally; people
will look fatter than they are.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example,
