Error code 37 means pump blockage error.
3 things:
Drain hose kinked.
A blockage in the pump or hose
Pump is jammed with something
Empty as much water out with a saucepan. Next -Taking the machine outside is well recommended - tilt the machine back onto a chair to get access to the pump. Unplug the wires to the pump and the earth wire. Lift the white lever and rotate the pump to remove. This takes a bit of forcing. The rest of the water will gush out. Check for things such as hairclips or coins etc. Blow down the drain hose to see if there is any blockage. Replace the pump and make sure the white lever CLICKS back into position. Replace wires.
Good luck
