Pool & Spa Logo
A
Anonymous Posted on Jun 22, 2015
Waterco sand filter has a sow discharge of water at the waste when the filter is runnin normally
Bill Jordan
Level 2:
  • Expert 375 Answers
  • Posted on Jun 24, 2015
Bill Jordan
Expert
Level 2:
Answers
375
Questions
Helped
121727
Points
672
Your backwash valve gasket need to be replaced.
How much sand goes in a waterco 8600 sand filter
Leave 10"-12" empty space above sand (freeboard).
1helpful
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
1helpful
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 • Pool & Spa
3helpful
I have a S-244T sand filter and I am noticing that my water level is going down about 3/4
When the pump is running is water discharging from the waste pipe outlet?
If so then the selector valve that switches the pump outlet to waste, backwash, filtering etc. is faulty.
How to use backwash to waste
When the filter get clogged the pressure in the filter increases and there is less water flow returning to the pool.
If your filter is a sand filter, when you turn the valve to backwash and turn on the pump it reverses the water flow in the sand filter to flush the dirt out of the filter to waste. Look at the window openning in the waste pipe and keep the backwashing goinging until you see clear water.
Then turn off the pump and move the control valve to Rinse, turn on the pump for a few minutes, this returns the water flow back to normal but the water goes to waste to make sure the sand filter is clean.
Turn off the pump and move the control valve to filter and turn on the pump. This mode is the normal operating mode and the pressure gauge in the sand filter will show a drop in pressure.
Some pressure gauge shows a red section to indicate when backwashing should be carried out.
I have a brand new S244T sand filter. During backwash cycle large amount of water discharges out of the waste line. Filter doesnt appear to be backwashing normally. Hayward is sending a replacement head. I...
When backwashing with this valve, it is supposed to come out the waste line. Also when in "rinse" and "waste" it will also come out the waste line. It is acting just how it is supposed to act.
9helpful
How do I replace the sand in my waterco t400 pool pump. Is there a manual available
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Nov 01, 2010 • Pool & Spa
Top Waterco Pool & Spa Experts
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
