Refrigerators Logo
Russ Posted on Jun 24, 2015
Defrost not working on my Viking VCSB483D Refrigerator. Flow Chart says it could be the LV Board. Is there any way to troubleshoot the LV board other then replacing it?
Using my troubleshooting flow chart for my Viking Refrigerator VCSB483D I was able to force the defrost mode. The flow chart says it could possibly be the LV board (Possibly?) there must be a better way to troubleshoot the defrost system other then replacing expensive parts.
paulmnindi
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jun 24, 2015
paulmnindi
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
4071
Points
43
Through my experience . replacing is a good to prevent future problems
3answers
Freezer will not deforst
Contact the service number. They have great customer service. At least they used to have great customer service hotline.
Cheers
2answers
2answers
Viking side by side refrig/coils are freezing over:?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Appears to be the condensation leaking into freezer bottom and leaking all over the floor. Drain has been thawed but leaking continues. Local dealer advised to get a fix kit from viking, but I have no...
Drain troth kit with clasp to fix defrost drain port and to program board for conventional defrost to 4 hrs run time. Viking parts dist has that available 8004889868
1helpful
Viking VCRB 364 LSS Refrigerator will not cool
return air ducts are freezing up in the freezer they are behind the rear wall of the freezer, unplug and defrost these ducts with a blow dryer for now , viking has a duct heater retrofit that will solve your problem, good luck
2helpful
Freezer is freezing fine, but refer will no get below 50 deg. F
sounds like a defrost problem, if you have frost on the inside back panel in the freezer then you have a defrost problem bad defrost timer/board or defrost heater or defrost bimetal thermostat. check em all.
Viking side-by-side -- Condensation
It really sounds like the defrost timer is staying on all the time.Have the timer checked.This must be a on going problem with this brand,I am getting a lot of them.So many things could be the problem,but the defrost timer is what really stands out,the defrost timer,does just that,it defrost only a certain short period of time,or it is supposed to.That is how you get frost free.If I can help any more please ask,but have the defrost imer checked ,or replaced.
1helpful
Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
2answers
Refrigerator cooling but doesnt get cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
