I know the HDFX but try downloading this maybe can be useful, sometimes the patterns are similar.
MARSHALL AVT150 AVT275 Service Manual free download schematics eeprom...
SOURCE: marshall mg50dfx was working great
please check the speaker leads in the back near the edge of the driver (the heavy metal part I think theres 2 in that cabinet )
SOURCE: The digital FX on my
This is likely to be an internal problem. Check the +5 volt power to the DFX board as a first step.
SOURCE: Marshall AVT20X hums and no
Likely one half of the full-wave rectifier has failed. Take in for repair. Sometimes output amp shorts to one power rail causing this. DO NOT continue to operate this until repaired as it will destroy the speaker!!!
SOURCE: I have a Marshall channel/dfx footswitch. The jack
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Testimonial: "Great, I'll give that a try now. Thank you so much."
SOURCE: is the input jack for
No it is not, they provide different functions and the impedance values are different. Hope that helps..
