ZEEPAD 7DRK Dual Core 4.2 Blue Android Tablet 7 Inch, Multi-Touch, Dual Camera, Wi-Fi May 2014 BLU Logo
M
Margarita Montes Posted on Jun 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i use my SD card on my Zeepad as a default drive to download apps
I have already D.L. an app manager, but doesnot give options when I want to d.l. an app.
JEM
Level 3:
  • Master 406 Answers
  • Posted on Jun 26, 2015
 JEM
Master
Level 3:
Answers
406
Questions
Helped
149222
Points
2858
I put an sd card into my tablet but my apps does not give me an option to save to sd card. What am i doing wrong. Not good at this stuff so help.
If it's an android, you can change it within an app - like camera. Go into settings and change default storage location from internal storage to sd card.
If the app can't see your sd card, make sure it's "mounted" within your device. Depending on the software version: Go to settings, general, phone/tablet management, storage, from here you should be able to see the sd card. It is either ejected or mounted. Click on the sd card, if you can see the folders content, then it is installed correctly.
Also, if it was used in another device, it may need to be formatted to be used in your tablet. You can do that from the same setting menu.
Hope this helps.
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
2helpful
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
How do I transfer apps and stuff to SD card on my trio stealth g5
If the tablet is running Android, in app manager click on the app you want to move and there should be a button 'move to sd card'. If it's 'greyed out', you can't move it.
How do I replace the SD card in my Android Zeepad?
does it have a sd card slot if not you can only free up some of your memory by deleting unwanted files and apps
2helpful
2answers
How do i download apps straight to sd card?
By default they're downloaded to SD card. What's the problem? Just move them afterwards to ExtSD if you want.
Another way (if you have your device rooted and familiar with Unix commands) is to change system start-up parameters to mount ExtSD as a /sdcard/download from terminal application.
How do I transfer apps and files to ext SD card on my binatone 7inch tab 744?
To transfer apps to SD card, you will use Settings-Apps, open the selected app, then choose Move to SD Card.
If you meant copying files, then use Explorer or other software with similar functions to copy the desired files. I think you actually meant the above.
1helpful
I tried to download showbox on to my zeepad tablet but now every time I try do to download something from the Google play store I cant
You might want to free up internal storage space on your android tablet. You can do this by moving some apps to an SD card that you have installed. Go to your app drawer, tap and hold on an app, and drag it to "App Info". Then tap move to SD card. Another way to free up space is to uninstall apps that you don't use anymore. If that still doesn't work, try installing a storage cleaning app. I would recommend SD Maid by darken. Hope this helped!
2answers
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
