Miele T9820 Gas Dryer Logo
M
Mr Appliance Posted on Jun 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find parts for this unit??? - Miele T9820 Gas Dryer
richie46
Level 3:
Top Expert:
  • Miele Master 12,962 Answers
  • Posted on Jun 25, 2015
richie46
Miele Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946176
Points
58151
Appliancepartspros.com has just about every part for all appliances. After you get the part number U might just find it on ebay for considerably less money!
1988 Ford Ranger XLT 4X4. Newly purchased dual fuel tank has an internal fuel pump, an inline pump, a fuel tank selector unit, and what looks like a second fuel tank selector unit (which is leaking).
The black reservoir/fuel tank selector unit you are referring to is the fuel tank switching valve, which is designed to switch between the two fuel tanks in your 1988 Ford Ranger XLT 4X4. This valve is responsible for directing fuel from the selected tank to the fuel pump and engine.
The second fuel tank selector unit you mentioned (part number 5sv2k) is likely a replacement part for the original fuel tank selector unit. It is not intended to replace the fuel tank switching valve.
The dual fuel tank system in your Ford Ranger requires both the fuel tank switching valve and the fuel tank selector unit to function properly. The fuel tank selector unit allows the driver to switch between the two fuel tanks, while the fuel tank switching valve directs fuel from the selected tank to the fuel pump and engine.
If the black fuel tank switching valve is leaking or malfunctioning, it should be replaced to ensure proper operation of your dual fuel tank system.
1helpful
Looking for a repair manual on a DCS 48-24g4-2n - I'm currently unable to find any documention on this unit. DCS has washed there hands of this unit!
if the manufacturer will not supply information or parts for this unit , then it is time to consider the problems of repair and parts avail;ability and the replacement of the unit
How to attach a thermostst to a whirlpool model number ACE184XPO
Hello Charles;
My name is Peter. I am a retired field service refrigeration and air conditioning technician.
I am in the dishwasher section of this website answering question.
Your question based on unit part number is a window air conditioner/ heater. So be it.
You have a old unit. I have made many service calls on these units. I know it is a old unit because the main control board is no longer available.
Is the problem the thermostat? How do you know? Have you used a multi-meter to Ohm it out. The thermal stat is part number 1185753. It cost $97.00.
If it is the heater. The heater part number is 1182568. The heater cost $137.00.
The rule of thumb is: " If the cost of repair is 1/3 or greater of a new unit, buy a new unit". "If the age of the unit includes parts not being available (Control board) buy a new unit".
You can go into the following web site, put in your model number and see the diagrams of your unit.
My professional advice, Buy a new unit.
Water Filters Lawn Garden Appliance Parts
3helpful
4answers
The fuel sender of my Montero Mitsubichi 1988 does not work, i need to find a new one or replacement, were?
1) SUNPRO FUEL LEVEL SENDER Universal; Part number, SUNCP7538, Manf. PN CP7538; $34.95 2) RCI FUEL SENDING UNIT Universal; Part number, R257060B, Manf. PN 7060B; $57.19 3) AUTOMETER FUEL LEVEL SENDING UNIT; Universal: Part Number, A483262, Manf. PN 3262, $41.90 4) DORMAN FUEL SENDING UNIT; Universal, part Number. RB7199, manf. PN 7-199, $36.07
Check out any of these universal fit sending units. They all have about the same ohms reading.
3helpful
My Konica Minolta bizhub C250 says replace transfer unit. I have looked for this part and can find nothing listed as a Transfer Unit. There are many parts listed but none specifically says Transfer Unit....
I am sending you this link because A) they have all the parts listed including part numbers and pictures. They are also a good source for parts and supplies. You might find one cheaper on the net tho. Also keep in mind that these transfer belt units are resettable by replacing a $5 fuse in the unit. If you have a local independant repair guy, maybe he can research this and reset your existing unit as they will usually go at least 2 cycles. I reset a dozen or more of these units per year for my customers.
http://www.precisionroller.com/search.php?q=minolta+c250+transfer+
Thank You for using Fixya.
WheatlandServices
Looking for the part # for a stapler unit for a canon 2020
I know only for U1/U2 finisher, and the part # for stapler unit is 4G3-0480-000
Send me mail for parts catalog on [email protected]
1helpful
After i change a used transfer unit into the c900, why is it still stated need to change transfer unit?
Is this a remanufatured part?
Epson's printers have microchipsets that indicate when a unit is blown. Some remanufatured parts may still have defective chipsets that prevent printers from using these parts. Try buying an orignal part or another comaptable but new part to see if this works.
Let me know how it goes :)
11helpful
4answers
Need info. on a Tempstar Comfort 2000 unit.
This is a 2 speed condenser fan control board, the tempstar part number is
1086071, if you google tempstar 1086071 you will receive 1 listing for the part for something like 44 bucks, but if you go to sears parts direct and enter the part number they have a factory authorized substitute part number 1088977 that you can order from them for $17.49, some tempstar units were shipped without this control unit and the 2 speed fan just runs off the contactor on high speed only to do that disconnect the control unit and connect the black and orange wires that ran from contactor to the control unit previously together, and then the fan should come on in high speed when the condenser is on. there is a kit that they shipped these control units http://icpindexing.mqgroup.com/documents/086477/48201222001.pdf, (just for you to look at) so all you really need to do is get the new part from sears or run the motor in high and get rid of the part all together, hope this helps.
Top Miele Dryers Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Steve Sweetleaf
Steve Sweetleaf
Are you a Miele Dryer Expert? Answer questions, earn points and help others
