I connect the tv the red light is on then sound clicking one time the red light turn off then one sound clicking and one more clicking and no turn on the tv
How many times this standby/power light
blinks at one time switch ON? Count it
carefully. These blinks are fault
indication, and known as blinking codes.
From the number of blinks occur at one time switch ON; you can get an
idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
