SOURCE: Samsung /sgh-a767 how do I reset the phone to
If you forgot your phone code, there is no way to get to your contact list....well, there is no risk free way to get to it. There is a utility (Samsung Code Reader) that you can use which will pull your code from the phone when it is attached by USB to a computer. But beware, as these applets are on sharing websites, so there is no tell if any of them are tainted with viruses.
Otherwise, if you are willing to forego your contact list, then you can hard reset your phone by following these steps:
A couple of things to mention:
1. This fix is NOT for unlocking the network (to use on other carriers), but rather this is for a 4-8 digit phone privacy lock that you may have forgotten what you set it to
2. If you run this fix, it will wipe out all data on the phone, effectively starting from scratch
3. You must remove the SIM card before initiating this or it will be wiped, also, leaving you with need to go buy a new one
4. You need to call Samsung to get the reset code: 800.987.4357 Tell them that you want to hard reset (wipe) your phone and you need the code. (They'll probably stay on the line with you and help you complete the task)
To hard reset the phone
1. Turn off the phone
2. Remove the back cover (battery compartment)
3. Remove the sim card
4. Turn on the phone
5. When it boots up and gets to the error message about the sim, enter the code provided by Samsung and press Return
6. Let the phone restore to original factory image and reboot
7. Turn phone off and install sim card
8. Replace back phone cover
9. Turn on the phone
10. You're ready to roll
SOURCE: i forgot a phone code, i want to hard reset my
hi
format the phone and use it.. this will able to fix your problem..
thank you
SOURCE: forgot password
Hi, if you have Phone Password problem, you can use the following solution: http://www.fastgsm.com/en/samsung/samsung/s3353/unlock-code
SOURCE: Samsung GT S3850 Corby II hard reset
* Put phone Download mode ( VOL UP + HOLD + POWER ON )
Download these
Follow This Step.
1. Download Multiloader
http://www.4shared.com/file/SLagBW72/multiloader_v565_.html
2. Handphone Download mode - press (Call/Green +volume up + Power ).
3. Samsung USB Drive.
http://www.sendspace.com/file/rf6jwp
4. S3850XEKC5 Files
http://hotfile.com/dl/112605771/748f030/S3850XEKC5.rar.html
5. Picture for Reference.
http://i302.photobucket.com/albums/nn83/errolkristine/mult.jpg
If u finished, connect phone with the computer in download mode.
and put the necessary files as shown in ref: picture and then click download.
