Question about Proscan PLT7223G 7" 4 GB Wi-Fi Black Tablet Android 4.1, LCD Touchscreen, 8000x480, 7 Hours
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
    Diehard:
    Visited the website for 60 consecutive days.
  • Proscan Master
  • 711 Answers
Could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Posted on Jun 29, 2015
Anonymous
SOURCE:
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
Why won't my 10.1 tablet charge?
Hello Pauline,
I know this must be frustrating. When this occurs, it is more times then not a problem with the hardware power port on the tablet. (the hole you plug the USB cable into on the tablet)/ The USB cable cannot make a solid connection because the port is damaged, and therefore electricity cannot get to the device or battery.
Do you have a warranty? I recommend seeing if the manufacturer will replace it. Also, if you have device insurance, you can try and get a replacement. Either way, you must replace the broken hardware power port.
May 25, 2015 | Hannspree HannsPad SN10T1
How can I fix the RCA 7in power port?
You should contact Authorized Dealer or Service Center to get it serviced.
Apr 26, 2014 | Tablets & eReaders
My charge got broke can i use a regular usb charger
Press "Volume +" together with "Power on", during 8-10 seconds. Choose first line in menu.
Feb 08, 2014 | RCA Ipod Tabletop Charger With Usb Port...
Instruction manual for irola dx752
I used a charger from my Samsung phone. Used the rectangular port instead of the regular port.
Dec 25, 2013 | Tablets & eReaders
Proscan PLT7223G 7" 4 GB Wi-Fi Black Tablet Android 4.1, LCD Touchscreen, 8000x480, 7 Hours Logo
190 people viewed this question
Top Proscan Tablets & eReaders Experts
Harrie
Ngoro
rostit
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
