Whasher fill and then drains
SOURCE: I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
SOURCE: Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
SOURCE: My Bosch MOdel WFMC 3200UC washer won't spin or
You haven`t mentioned whether you`ve checked the pump or not and obstructions and debris in Bosch pumps is very common, so I`ll assume you didn`t and explain how you can do it yourself.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
