Televison & Video Logo
Daniel Artadi Posted on Jul 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the comcast remote control codes for portland dvd player
JP Meneide
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 483 Answers
  • Posted on Jul 02, 2015
JP Meneide
Master
Level 3:
Dedicated:
Answers
483
Questions
Helped
177878
Points
2858
Hey Daniel!
  • None of Comcast Remotes can control the Portland DVD player.There are no programming codes available.
  • However try calling Comcast tech support, they might be able help.
  • Here is a link to their support website. Or call 1-800-COMCAST.
Good Luck,
JP
Get Help Support
1helpful
How do I program a dvd player with the new xfinity x1 remote? The instruction manual does not tell us how.
It is my understanding the xfinity remote is designed only to control comcast set top box and TVs. It also can control audio receivers. It is unlikely you can control a DVD player with it.
At best you could try and use the programming instructions on page 5 of the manual and see if it picks up your DVD player. Otherwise it might be better to use the existing remote controller you have and program the Comcast set top box to it. You need to find the codes from the programming instructions of the original remote control and you will also need to know the model number of your comcast box.
Hope this helps.
https://x1.comcast.net/webportal/assets/pdfs/RemotePairingGuide4.26.11.pdf
Ok/select doesn't work with magnavox dvd player
Hi, make sure you Comcast remote is in the "DVD" mode before attempting to work the DVD features. If it is still not working. You need to reprogram your Comcast remote to a different Magnavox DVD code because the code it is currently set for not fully compatible. If you need the instructions to reprogram your Comcast remote go here. If you would like to purchase a new Magnavox DVD player remote you can also search on Replacement Remotes for your DVD player's model number located on the back of the unit. If they have it, it will show for purchase.
I have a Panasonic DVD-35 player. Lost the remote. Have programmed my Comcast remote to work and it does. Problem I have is I need to get to the SETUP screen to make an audio change. Cannot get to screen....
hi,
u didn't mentioned the model of comcast remote.if it is DVR 3 device then you can control panasonic dvd through it. the programming code is 20490
if its comcast DVR 3 divice univeral remote control then try these code 0490,0632,1490,1907
ok
Need remote code for Apex AD-1201 DVD player w/Comcast universal remote (red OK button, black Comcast letters)
I don't have the original control remote for Apex Ad-1201 DVD player. I would like to use my Universal Remotes: Radio-shack USA "flag" 4-IN-ONE Remote and / or RCA 312W three component remote. I got the codes from the manuals but my DVD player doesn't work or turn off (only ejecting; open and close) with pause button. Could I get a possible code (s) for these Universal Remotes?
What is the code for my dvr850 on a comcast remote
I don't know know you specific DVD player all the manuals for the comcast remotes are located here.
I'm looking for the code to a portland dvd player
try this page for a huge list of tv, vcr, dvd, stereo, etc. codes...
www.oneforall-na.com
8helpful
2answers
Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Code for comcast remote
If using the comcast remote to control your dvd player, then review comcast manual for the codes for dvd. If the manufacture isn't listed or the codes don't work, then there might be a range of codes in the manual you can try.
Otherwise you can contact your dvd manufacture on purchasing a new one or get a learning remote.
Need help finding DVP3140 remote programming code for comcast universal remote
Since the codes that Comcast gave you did not work, there is a very high possibility that the remote control is not compatible with the DVD player. You cannot expect universal remote control to work with all devices, regardless of its make. Philips does not have codes for this DVD player because it is the maker of the universal remote control that sets the codes.
1helpful
Comcast universal remote codes don't work for zenith zhd-311 dvd/receiver/home theater
Had the hardest time finding a code for this old TV.
Posting now so that others can find this solution.
White-Westinghouse
Modle: WTV-11901
Comcast Remote Control Code 0451
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
