SOURCE: Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
SOURCE: Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
SOURCE: Dark Pictures
Hello zapatista,
I found this on cannon's website, so it should work.
If it dosent let me know and i will find other solutions for your problem.
"**Exposure Control**
*Exposure Compensation*
The settings can be adjusted in 1/3 stops in the range -2 to +2. Adjust the exposure compensation to a positive value to avoid making the subject too dark when it is backlit or shot against a bright background. Adjust the exposure compensation to a negative value to avoid making the subject too bright in night shots or when shot against a dark background."
SOURCE: Olympus zoom camera ED lens #sp51ouz
it seems that the moter or track is either damaged or out of line this will need to be fixed by an engineer sorry
SOURCE: Everytime I turn on my camera a lens error comes
check to see if part of the lens cap snapped off into one of the connection areas or if the lens cap sensor is a button that is stuck down. If not, there may be damage to the electrical and or optical hardware behind the lens.
