Corrective Action
Tectrix Climbmax Error CodeReasonSuggested Action
5
No Slack
Enter test mode and test switch, adjust switch, inspect display cable for cut or crimp
Tectrix Climbmax Error Codes
Info for Error code 105
105. (01101001) Phase 2 to 6 - Comms Error Time Out
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Note: If the product is an IW, the wrong Motor Control Module may
have been fitted. Replace with a compatible part.
Phase 2 to 4 and Phase 6
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor (Phase 5 and 6).
Action: Replace Rotor Position Sensor. If this corrects
the fault, refit the original Display Module or
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor Position Sensor.
Your Error code is 94
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106 106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
Control Module.
Phase 2 to 3
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
That is Error code 49, 49. (00110001) Phase 2 to 6 - Cold Valve Faulty (proportional)
The Motor Controller module has measured a voltage from the valve diagnostic
circuit that indicates the cold valve is faulty. The most likely cause is that the valve
harness has not been connected correctly or the valve is open circuit. See fault code 48 for service procedure. 48. (00110000) Phase 2 to 6 - Hot and Cold Valve Faulty
The Motor Controller module has measured voltages from the valve diagnostic
circuit that indicate both the hot and cold valves are faulty. The most likely cause is
that the valve harnesses have not been connected correctly or the valve is open
circuit.
Primary Source: Wiring.
Action:
Check the valve harnesses are correctly fastened to the valves or the pins are not
bent backwards.
Secondary Source: Water Valves.
Action:
Check the valve coils are not faulty (open circuit).
Tertiary Source: Motor Controller module.
Action:
Replace the Motor Controller module.
That is fault code 49
Here is fault code info.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
for the first part take the usb plug in end out of the port in your computer and put it in a new one this worked for me just today. as for the second part make sure that if you have a security system or firewall that you let the program acsess it hope i was able to help! :)
