Hi, This model has 4 HDMI inputs, do you get same problem in each HDMI input? Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box? Below are few helpful tips to connect HDMI input.. 1. Ensure that your HDMI cable is certified. 2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source. 3. Reset the accessory device and the TV. • Turn on the TV • Select the HDMI channel • Turn on the accessory device 4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable. Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty. Hope these info will help you. Thanks.
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
I am having the same issue. I believe the issue to be somewhere in the transition between HD channels and non HD channels. A work around is to switch the input to another input such as DVD and then switch back to your cable input (mine is the HDMI input). I'm probing the web looking for why this happens and if there IS a permanant fix.
