Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
SOURCE: Tried to download some apps on my digiland 701Q tablet I'm told I'm not able to accept downloads .
Your memory for apps might be full. Go to Settings > Storage and look at the top bar graph. If it says it's full then there's your problem. You'll have to delete some apps or clear data and cache on some in order to get some room freed up. You might be able to move some of the apps to an external SD card if you've put one in the slot if you have a slot.
Or, if the top bar graph says 00 bytes of memory then your
app partition got trashed somehow - probably a faulty internal SD memory. I have this problem on a Nobis NB09 and so have a lot of other folks when I Googled Nobis stuck on Go and NobisNB09 won't boot up etc. Nobis fixed it once but it lasted only two or three weeks and now they won't issue me another RMA number. I would advise everybody to not purchase Nobis - now run by Bidwell products as they don't seem willing to honor warranty.
