Chances are one of two sensors is broken or out of adjustment.
Either will cause engine shutdown when blades are engaged.
The first is the seat sensor. If you rise out of the seat with the blades engaged, the engine will die. That sensor is usually a switch located under the seat. The second is the Reverse lever (Or gear position). Newer tractors will shut off if operated in reverse with the blades engaged. This sensor may be more difficult to find, but it is usually another switch located around the gear shifter (or hydrostatic control lever).
