Question about GE Accesspoint Keysafe-original - In Package
How do I open a GE AccessPoint KeySafe Original #001004 spare key box when I don't have the code? What is default code?
I just purchased it but it is close, what is the default safe code to open it? Thanks
RUSH BACK TO THE STORE WHERE YOU BOUGHT IT. The only one who can give you safe code is the one who sold it to you.
As if it has a default code? Electronic cosdes might be reset but of sourse, you should know the original.
https://www.youtube.com/watch?v=_tqTp57YfCw
http://www.safeoptions.co.uk/blog/how-to-change-number-on-keysafe-lock/
In any case, if someone with experience with a safe similar to yours might be interested to share his experience, you should provide make and model of you unspecified safe.
I've been lookin for safe mnauls on internet and got this one:
http://www.sargentandgreenleaf.com/pdf/630-302_6120_op.pdf
and also this one:
http://hilkab2b.co.uk/manuals/s-25ea%28ii%29.pdf
How To Change Number On Keysafe Lock Safe Options
Guses might find some better information should you provide make and model of your safe.
Aug 22, 2015 | Home Security
How can I open locked safe I have forgotten the numbers
perhaps a call to the manufacturer will produce the combinayion
Apr 24, 2015 | GE KeySafe GE Security Supra 1000 / 001000...
Change code combination
Setting the Combination
1. Remove the key holder from the KeySafe by pressing the RESET button, followed by the OPEN button. Pull down on the key holder from the bottom of the KeySafe
2. Remove the bracket. Press the Release tab on the bracket and slide the KeySafe upward until it is free of the bracket.
3. Remove the plastic card attached to the bracket. You will see ten numbered buttons with arrows. These numbers correspond to the numbered buttons on the front of the KeySafe. An up arrow indicates that the button is not selected, a down arrow indicates that the button
is selected as part of the combination.
4. Using the screwdriver tip on the plastic card, apply light pressure
to rotate the arrows on the buttons you've selected for your combination a half-turn to the downward position until it snaps into place. Caution: The arrows must either point up or down, with downward arrows representing the numbers in your combination. If any arrow is pointing left, right, or is not fully seated when turned downward, the combination will not work. Improperly setting the combination is not covered under the warranty.
5. Return the plastic card to the bracket for future use
Mar 10, 2014 | GE AccessPoint Digital KeySafe 001847
I have a supra touch pad key lock but the code accidently got changed and no one can remember it how do we open it now
Well there are may ways,,, I cant really post them here as this is public and a lot of BAD people use the net too.
I once forgot my combination but I used this basically it will generate every possible combination for you, a 5 digit sequence will take about 20 minutes to go through..
Also I remember once a friend left for vacation. While he was out a clever Thief used battery acid to melt away the plastic coating and then used a chisel and hammer or something abound that thereof to break the rest open.
and as another friend told me, When all else fails a Huge Hammer works.
Please remember these locks are Advanced and you should call a locksmith as it will be wrong of us to tell you how to bypass.
Dec 28, 2012 | Supra 001004 Push Button Lock Box Key Safe
Ge universal remote 24991 v2 need code for apex dt250a or rca stb7766c
There is no setup codes for Apex or RCA STBs with this GE remote control.
Oct 11, 2012 | Apex Digital Apex Apex Remote Control Oem...
I dont know the combination for a supra keysafe that is on a door of a property I have just purchased
Well, you MIGHT be stuck and out of luck, however there are some tricks you can try. Check out the blog on http://suprakey.org/ - they have several solutions for those that need to reset the combination of a Supra Key lockbox!
Good Luck!
May 23, 2012 | Supra 001004 Push Button Lock Box Key Safe
LOST CODE ON SUPRA C LOCKBOX
I have just moved into a house that has a supra combination code key safe mounted on a wall outside the back door , it was put there by the first owner who died ,the second owner never used it and don't know the code,I just thought it would be handy to use as we are going away in June to France and its away of leaving a key in case the alarm goes off while away so a neighbour could deactivate it or the police so they don't have to brake down the door or if I get locked out I could have that key for emergencies so is there a way I could find the code for the safe please?
Aug 31, 2011 | Supra 001004 Push Button Lock Box Key Safe
How do I rename the netgear connection and make it security enabled? I have WG602v2 router
Please follow steps to fix your issue
1. Connect the computer to 1ST Accesspoint using a Ethernet cable.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the Accesspoint (usually http://192.168.0.227).
4. Login to the Accesspoint (Username = admin Password = Password unless you have changed it).
5. click on Wireless Settings in the left hand side menu under Setup.
6. Change the network name SSID to (any name) and click apply.
7. Click on Security Settings in the left hand side menu under Setup and select Security Type as WEP.
8. Select Authentication Type as Open System.
9. Select Encryption Strength as 64 bits.
10. Under Security Encryption (WEP) Key in the Key 1 box enter the same 10 digit key that was used on the router before.
11. Click Apply.
Hope this will help
Thanks for using Fixya
Jun 12, 2010 | Computers & Internet
Please follow steps to make your network secure and change network name.
11. Click Apply.
Hope this will resolved your issue
Jun 12, 2010 | NetGear WG602 54Mbps Wireless G Access...
Network Key?
You can get the WEP from the wireless accesspoint or the wireless router. It's a 10 digit code usually seen on the wireless settigs on the setup page on the routerr. To access the setup page of the router you must be on a computer tht is directly connected to it.
step 1. Find the default gateway. start>run> type cmd and click ok. on the black screen (command prompt) type ipconfig. You should find a default gateway there.
step 2. open a browser like internet explorer. On the address bar type http:// then the default gateway. example: http://192.168.1.1
step 3. It may require you to enter the username and password for the router/accesspoint. Usually it's on the owner's manual.
step 4. Once you're in locate the wireless settings. Usually it's a tab at the top or left of the page. you should see your WEP there.
Oct 08, 2008 | Toshiba Satellite A45-S151 Notebook
GE Accesspoint Keysafe-original - In Package Logo
305 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
