Question about HP Designjet T610 InkJet Printer
HELP!!! Designjet T610 Prints Blank Pages. When printing multiple pages the printer start to print blank pages after the 1st or 2nd page. What can I do?
If you print pages individually the printer is fine but if you try to print multiple pages at one time the pages start to fade and then just print blanks. I have cleaned and aligned the printer heads several times but is does not seem to fix the problem. PLEASE HELP!!!!
    Scholar:
  • HP Expert
  • 123 Answers
When the print fades out part way through the print, a particular print head or heads is running out of ink. There is air in the ink tubes that has migrated to the print heads. Air gets in past the print head check valves when the check valves are worn. When the ink system is not pressurized (plotter off or idle) and the atmospheric pressure goes up, air will be pushed into the ink system. The fix is to replace the ink tube system and the print heads. Designjet 500 800 ink tube systems
Posted on Jun 16, 2016
  • HP Master
  • 1,915 Answers
This type of issue is usually related to either software configuration or driver configuration. Make sure you have the current drivers that HP offers installed. While at the HP website, also ensure that your firmware is up to date.
Posted on Jul 10, 2015
    New Friend:
  • 90 Answers
Go to Staples in your area or try the staples.com website you might be able to get the same kind of printer or better. the people at Staples are friendly and they will be able to assist you they know a lot about these kind of things such as printers, and computers, and tablets and stuff. See if they can help you better.
  • 1 more comment
  • Sandra P
    Sandra P Jul 10, 2015
    Thank you Felicia, unfortunately these printers are $7,000 to $12,000 for a new one so I would rather try to fix this one if possible.
  • Felicia Sweeting-Harris
    ok that would be great. see if Staples can find you an economical solution to your problem they are very nice.
    you are very welcome Sandra P glad to assist you.
Printing laserjet fades from left to right on text only
Anthony try removing the cartridge and gently tilting backandforth a few times. Re-install for good news!
Mar 12, 2014 | HP LaserJet 4650 Color Printer
Slow printing
Slow printing I have a Laserjet 4200
Jun 26, 2013 | HP LaserJet 4200 Printer
My HP C6380 won't print multiple copies of a page even though I select how many copies I want of the page . I have to keep printing each page individually which is very time consuming.
what is he OS ?........what connection USB/wireless ?..........From what application you are printing? ..........have you checked the printer printing properties and ticked of the collate check box where you have selected mutiple pages ?.....
Jul 15, 2010 | HP Photosmart C6380 All-In-One InkJet...
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
HP 3210 Multi-page print problem
Dear Martin Luke,
Take a look at the posts on "black ink problem" on this site. There are 9 offers of solution.
Many of us with this defectively-designed model have the same problem. Some say the answer is to do with button pressing, but action may need to be more radical and messy, and involves forcing the blockage out of the ink feeder tube etc.
Dec 30, 2008 | HP Photosmart 3210 Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Designjet T610 InkJet Printer Logo
251 people viewed this question
Ekse
Thomas F. Schneider
