Question about LG 42PX4DR 42 in. Plasma TV
Need a passord to reset to factory settings please anyone ? hanks in advance
  • ilidio gouveia Jul 13, 2015
    thanks but it dosnt got any factory reset optipn
    i try everthing u can imagine and still cant go to factory settings . works fine with satellite but when i change to normal aerial dosnt give me the option to search for new channels the only thing didnt try was with a 4 numbers pin because i didnt find the correct one yet i will keep on trying lets see if i got any luck thanks for ur reply.
    Top Expert:
  • LG Master
  • 10,875 Answers
There is no passord,go to settings and find reset to factory and click on it
Posted on Jul 13, 2015
    need a factory reset as i cant get any channels and dosnt let me search for new ones so if i reset it to factory i will be able to set up as a new tv. please anyone?
  •  johnny rebel
    johnny rebel Jul 13, 2015
    unhook the antenna and search for channels then hook it up and search again
6ya staff
SOURCE:
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
Please i really need a quick answer on this, am having a problem on my china i9500 it asking me for (4-8) passord and i cant remember it
There is only 2 possible ways, "remembering the password" or "saving important data to a SD card or computer and having to factory reset it".
Incase you want to factory reset it the steps are below. Hope this helps.
step 1 : power down phone & remove SD card "in some cases the SD cards memory has been erased, so remove it to be safe"
step 2 : press and hold the volume up, home button, and the power button at the same time for 5 seconds then release the power key only.
step 3 : wait for the recovery mode to boot up, and then use the volume buttons to navigate to "wipe data & factory reset"
(Incase of SD card use) step 4 : when your device is has booted up it will start up as if you just got the phone. When your done setting up your device, insert the SD and allow it to load into the device. (With some smart phones it might be safer to power down the device and then insert the SD card, allowing it to boot up with the phone)
Now you're all set. Hope this helped.
Oct 30, 2014 | Samsung I9500 Galaxy S4 16GB Quad-Band GSM...
Cannot reset time or date on ICF-CL75iP
Solution NO, Same problem YES! Our power was out for about 8 hours and now we cannot set the time or date! Surely someone has a solution! Please Help!
Jan 29, 2013 | Sony Dream Machine FMAM radio with...
Forgot my windows ce password need to rest my laptop back to factory setting
Forgot windows password, we can use Windows Password Reset to reset our windows password.
The steps are:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password
So easy,right?
Jul 08, 2012 | Computers & Internet
I need the key combination to do a full reset on a Lexmark x6675 - can anyone help? Thanks in advance for any assistance forthcoming - Jeff
From the printer control panel, press Setup button > Defaults, press OK > Set Defaults, press OK > Use Factory, press OK. You will then be asked to select/enter your preferred printer settings just like the first you set it.
Source: How to Reset the X5600 and X6600 Series Printers to Factory Defaults
Jul 26, 2011 | Lexmark X6675 All-In-One InkJet Printer
I need my wireless network name and security password. How do I get this?
If you do not know your wireless security password, you will not be able to get it. Your only choice will be to reset the router and redo the setup. to do this - find the reset inset on back of router...press with pin or extruded paperclip end. hold down button while removing power, continue to hold, leave disconnected for 1 minute, hold down button again - plug in unit. release button. it should now be set back to factory. You will now need to login to the router - using the factory settings (likely a web interface - connect to router hardwire). Passord likely blank so hit enter with Admin user...again likely this default but manual will tell you. Good luck!
Jun 15, 2011 | Computers & Internet
I have a Wireless G Access point WAP54G and because i had lost the username and passord we had set up i reset the device and then since the device didn't go back to the default username and password I...
Try connecting straight to the router and go to 192.168.2.1. or 192.168.1.1
Default login is admin.
You can check your configuration settings here, as well as restore it to factory settings.
May 10, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
I don't remember my passord on my netgear router .How do i reset my password on my netgear router.
You can reset the whole thing.
Use the small recessed reset button usually next to the power connection, hold it down with a pen tip or paper clip fro about ten seconds.. Reset all settings to factory, including passwords.
Power off and on then use your browser to http://192.168.0.1
User = admin Password = password
If you have like an xbox or laptop wireless you'll have to re-configure them too, to connect again.
Dec 27, 2010 | NetGear WGR614 Router
Can't access configuration setup
There was a small reset switch on your router, press the reset button for 5 second to reset the setting into default factory settings. Like in your case it is possible that the router need to reset for the first time.
Kindly let me know for further more assistance.
Thank you for using fixya.
micro-
Dec 12, 2009 | Zyxel Prestige 320W Wireless Firewall...
Nokia hanking
*#7670# -- This is the Code for default Factory Settings
*#7370# -- This is the Code to Format the Phone
Note - All the data will loose(Ex. SMS Phonebook) if you use second one
thank you
Apr 14, 2008 | Nokia N70 Cellular Phone
LG 42PX4DR 42 in. Plasma TV Logo
65 people viewed this question
Ekse
RONALD CARTER JR
