Brother MFC-8460N All-In-One Printer Logo
A
Anonymous Posted on Jul 14, 2015
Please wait light is flashing - Brother MFC-8460N All-In-One Printer
1helpful
Defy F350 Upright single door freezer ON/OFF (green) light keeps flashing.
unplug it and wait 10 min, then plug in. That may reset it.
If not, observe the flashes of the light as it may be giving you a code to lookup. - like it will flash 3 times, pause, then flash 5 times, then pause longer, the repeat.]
lookup error code 35.
Dec 04, 2019 • Freezers
97 Chevrolet Lumina. Won't start. Lights, horn, radio all work. Tried jumpstarting. Still nothing. Tapped starter and it started but cuts right off. Noticed Security light flashing. Checked all...
You have a security issue going on. Try turning the key to the on position and leave it on without trying to start the car. Wait about 10 minutes and the light will stop flashing and come one solid. Then try to start the car. Turn the key to the off position. Wait 60 seconds and then turn the key to the on position. See if the light is still flashing. If it is then try the process again. If it isn't flashing and it is on solid then start your car.
97 cavalier cranks will not start theft light stays on
Is the security light flashing? If so, turn ignition on and wait for 10 minutes and light should stay on solid. Then try and start the car without turning the ignition back off. Then turn off ignition and wait 1 minute. Then turn ignition on and see if security light is flashing. If not try and start your car. If it is flashing, try waiting again with just the ignition on and see if it goes out.
Under Attention, orange lights are flashing for black and white and color. I have put new ink cartridges in turned on and off and still flashing orange. Wher it says Start/Copy, a big E is flashing. ...
I would try to remove both ink cartridges.
Close cover and turn off printer and unplug from outlet.
Wait at least 15 minutes, this will let printer to completely reset.
Turn on printer and wait for printer to stop.
Install both ink cartridges.
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
1helpful
2answers
I have a 2003 nissan xterra...can't get the idiot lights for the airbag and check engine soon to go off...and the keyless entry will not work, battery in the keyless has been changed and the vehicle has...
Take it to a different shop. Something is wrong with it. However, when the airbag light is on, that means the airbag will not deploy in an accident. You should have that fixed first. The dealership is the best option for making the keyless entry work. If this was at all helpful, please rate. Thanks for asking.
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Error message 0xf0af8005 and green and orange flashing lights
Please follow these instructions to reset the printer. If that doesn't work, try again but wait longer before reconnecting. Otherwise, here's the home support page for your machine. You can look up the meaning of the flashing lights there as well.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
1helpful
All LEDs are flashing
If you hold the two buttons down, this will give you a secondary error code which will tell you the exact error. All lights flashing is a service error.
Norman Weimar
Norman Weimar
k24674
