I lost the book for my LM-1079 universal remote and I would like the codes for a Vizio tv and also how to set it up. Thank you (:
SOURCE: Can't find codes for universal remote -- purchased for Vizio TV
Unfortunately, there does not seem to be any truly 'universal' remotes and we have two that won't 'learn' from the originals either.
They should be called 'multibrand' remotes.
Use your Vizio model number of your set and try here:
Remotes
This seems to be the best site but they are also not infallible.
SOURCE: code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
