Panasonic Viera TH-42PX80U Plasma TV Logo
736 NV Posted on Jul 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic TH-42PX80U 2 blinks
2 blink
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Jul 16, 2015
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986789
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Testimonial: "tv blinks 2 search the site but nothing comes out You could help me with that thank you very much"
  • The Knight
    The Knight Jul 17, 2015
    There is blinking codes details to many many models of Panasonic Plasma TVs. Search the site with these keywords.
    Blinking codes
    or
    Panasonic Plasma Tv blinking codes
    Type this at its search box [at the top right of the display window] to get gathered associated pages.
5 Related Answers
Anonymous
  • Posted on Aug 13, 2008
SOURCE: TH-42PX80U
i have the same problem but i have 11 blinks
Anonymous
  • 61 Answers
  • Posted on Oct 09, 2008
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Anonymous
  • 1779 Answers
  • Posted on May 23, 2009
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Anonymous
  • 458 Answers
  • Posted on Dec 06, 2009
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
A
Anonymous
  • Posted on Apr 29, 2010
SOURCE: Panasonic TH-50PZ80U plasma wont turn on
YOU MUST BRING THIS TV TO A REPAIR CENTER EXPECT AT LEASE 450,00 AND MAYBE MUCH MORE THERE MAIN PROBLEME IS SC BOARD AND OFTEN SD SU AND WORSE PANEL !!
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
I have a 42" Panasonic
If you remove the back panel and check on the power supply board, you will find a couple of bulged caps that need to be replaced, or just replace the power supply board.
I have a TH-42PX80U. The picture went black and the red light does NOT blink. I tried a different power cord in a different outlet and still won't turn on.
More likely to have power supply module failure, that will be the first place to look.
Most common failures in PLASMA TV are due to bad power supply module, Z and Y Sustain modules.
8helpful
2answers
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
2answers
Blinking red light and no picture
The 8 blink condition is a shutdown associated with a sustain voltage, possible that the set only has a loose conncetion, in most cases requires a board replacement, except on the TH-50PX80u, almost always a connection
6helpful
2answers
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
