Question about Frigidaire GLTF2940ES Front Load Washer
HOW I DO FIX ERROR DOOR UN LOC
Thi unit door unloc in the middle of cycle
2 Suggested Answers
6ya staff
SOURCE:
richroth
Richard Roth
  • 9472 Answers
SOURCE: my washer is loc and
The Control Lock (child lock) is on: To prevent accidental operation of the washer or alteration of the cycle settings, press and hold the lock symbol until you hear 3 beeps and ?LOC? is displayed.
To cancel, press and hold the lock symbol until ?LOC? is no longer displayed. To put the control into control lock you do the same thing.
Posted on Jul 30, 2011
Wmf540 beeps
Not sure your entire question but if no cycle is chosen or running and you close the door and the power trips then it is definitely your door lock mechanism. This is located to the right of the door behind front panel. If it tripped out in the middle of the cycle and by closing the door you are restarting the cycle then it will depend on where in the cycle you are up to. Of course it can always still be the door switch itself I don't usually find them tripping the power. If the machine starts the fill but trips out it is likely the inlet solenoids. If the unit fills some and then trips it is likely the motor. If the unit fills washes and then trips it is likely the drain pump. If the unit fills washes drains and then trips it is likely the motor. Of course at any of these points it can be any of the pc boards. So if you know where in the cycle it trips this will narrow down the choices.
Jul 08, 2013 | Washing Machines
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Oven cleaning mode quit in middle of cycle. unit
prob blew the high limit thermostat in the rear of the unit, pull unit out remove back panel and check that thermostat for continutiy with a meter.. hope this helps
Feb 05, 2010 | KitchenAid Kitchen Ranges
My error message says FC the oven door is locked I tried unplugging but that did not work . The cleaning cycle was stopped right after it was accidently started.
The self clean option usually can't be stopped once its started. you may have to let it finish its cycle (a few hours) and see what happens from there. It also sounds like you could have a bad door sensor switch.
Aug 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Inside the door panel
If you mean the area where the gasket is...yes.  This is a mullion heater designed to prevent freezing the gasket to the box.  It should be slightly warm.  Some units have the option of turning thi feature off.  Check your manual.
Nov 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
LOC for oven door is unable to unloc
Put the oven in Self Clean mode for 3 minutes and then cancel.. if if that will release the relay that controls the lock. If that doesn't work, Unplug the oven for 10 mintues, then plug it back in holding the CLEAR button down. If neither of those work you will need to contact a service repair man.
Jul 19, 2008 | Ovens
If wiring to door lock motor are ok then the motor may need to be replaced. Need to check the resistance of the motor with a meter. If it checks open then the motor is bad.
Oct 03, 2007 | Frigidaire GLEFM385D Electric Kitchen...
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
93 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
