I have a nextbook i reseted it and everything because i drop it last week and it git frozen......it was cutting on i just cant press on anything do you think its broke or it could be fix?
Hi turn it on normally press & hold power button for 30 seconds it should turn of don't do anything for 3 minutes then press the power button for 5 seconds hopefully it will power up normally. cheers
Try using the reset switch (a small hole in the case) put a straightened paperclip or a pin very gently through the hole until yuo meet a resistance. Press very gently and this will reset the tablet.
I am not directly familiar with your particular tablet, but try this.
Locate the reset button's access hole - usually a tiny hole either on the back of the tablet or on the edge near the various ports and connectors. If you have a manual for the Tablet, it should tell you the location of the Reset button.
Press the button by inserting a paperclip or similar GENTLY into the hole. PLEASE MAKE SURE IT'S NOT THE MICROPHONE HOLE YOU"RE LOOKING AT.
You should feel a soft click when the recessed 'Reset' button is depressed. Hold it down for about 10 seconds, after which the Tablet should reboot itself, and hopefully will now run normally again.
Note that you WILL NOT lose any data or settings by resetting your Tablet this way - it merely restarts the microprocessor which may have frozen.
Happened to me today. Fix: Boot it up and go to Settings > Backup & reset > Factory Reset: Check the Erase SDCard Data Box. Make sure you backup all your important information to the External SDCard first using Astro or something. Enjoy your fixed tablet after rebooting again and going through the Wizard for the Last time.
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that. It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press. I hope this will help you and that your tablet will work fine for you. Let me know if you had any success.
Sorry guys I ment to say got where it says git
