Panasonic Lumix DMC-ZS35 Digital Camera Black Logo
M
Mary Ann Stalnaker Posted on Jul 19, 2015
I have my camera set on intelligent mode but when I try to take a picture in front of a window the subject is too dark. How do I adjust?
1helpful
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
4answers
Dark Pictures
try reseting the camera back to default settings, there should be a function for that in the menus or a small reset hole somewhere in the camera.
1helpful
2answers
Photos are fuzzy. At the time it takes 52 picts. a round. Would they be sharper if I reduce the picts?
Hello MaryRoth,
Photos are fuzzy due to many reasons and the main two reasons are that the subject is out of focus or the subject or the hand shake during the time of taking the snap.
Please make sure that you select appropriate picture modes (Macro, Portrait, Landscape etc..) when taking snaps. Make sure that when you press the click button half-a-way (known as AE mode), the subject is still in focus.
Try using a Tripod stand in case the hand is not steady or try increasing the shutter speed if its an SLR camera. That should help.
Let me know if that works.
Regards,
Srinivas
Apr 27, 2009 • Cameras
Blurry pictures in Sports Mode
Well, Sports Mode is a fully automated mode, which I believe tries to balance the exposure toward faster shutter speeds. An over all dark photo indicates an underexposure. You can adjust for underexposure by dialing in a 1/2 stop or so on your exposure compensation dial.
However, dark AND blurry indicates that you just didn't have enough light. The first thing you want, for that same shooting situation, is some faster film. Go up at least an f-stop or two (eg, if you're shooting with ISO 100 film, try ISO 400).
Pay attention to the shutter speed the camera is setting. If you're stilling still, photographing action, you'll want a pretty fast shutter speed, or you WILL get blurring. I'd recommend at least 1/250th second, faster still if you're trying to freeze motion.
A more advanced technique is to pan with your subject. Follow the subject with the camera, and use a medium to medium fast shutter speed (1/60th-1/250th). You will get some blurring, but if you learn this well, your subject will be pretty clear, and the background will blur... thus including the suggestion of speed in the final photo, rather than something that looks frozen. That can deliver a much more satisfying shot.
I have used Canons for years, but I avoid all of the those special modes, like sports modes. They're really trying to deliver some help, but these are techniques you should learn in any basic photography course.
If you set the camera to Av mode, you can choose the widest aperture available for that lens, which will always get you the fastest possible shutter speed -- thus, the least chance of blurring. If you still blur, you need more light, a lower f-stop number, or faster film.. those are the only cures.
Daytime Photos A Little Dark In Auto Mode
If you are in full auto the camera is going to meter to the brightest point. If your subject is in the sun you should be ok but if your subject is shaded then they will come out dark becouse the camera is metering for the brighter background. You might try seting your camera in AV or TV mode and then set your camera to a single AF point. This will let you camera meter to just your subject and not the background. Youe could also try using a flash fill to balance out the light.
Why do my pictures look too dark?
You may need to use the flash. Make sure the setting is not flash off. If you're using the flash, make sure your subject is within the range of 14 feet for wide angle shots or 11 feet for telephoto shots. Use Image Expert to adjust the picture's brightness and contrast. Try adjusting the camera's exposure or sensitivity settings (use the Manual user mode). If you're taking pictures in the Manual user mode, look for the EV! warning that appears on your LCD screen when you are taking pictures out of the ideal exposure range. If you have trouble setting both the aperture and shutter speed manually, try adjusting the aperture and letting the camera choose the shutter speed with Aperture Priority mode. If you're using the macro mode to take a close-up photo, be sure to provide adequate lighting for your subject. If you're taking a picture at night and you want to light up the background as well as your subject, use the camera's slow synchronized flash mode. If you need more light, attach an optional external flash to the camera's hot shoe.
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Best situation to use each of the shooting modes
Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Indoor Indoor mode enables you to take pictures while indoors by allowing the flash to reach farther away. Beach & Snow Beach & Snow mode enables you to take pictures of scenery containing white sand or snow. Cuisine Cuisine mode enables you to take pictures of food by increasing the saturation, sharpness and contrast settings to take sharp, vivid pictures of the subject. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Shooting modes
The shooting modes are as follows: PROGRAM (P)/AUTO Modes. Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM AUTO (P) the brightness (exposure compensation) can be adjusted. Portrait. Suitable for taking a portrait-style photo of a person. The camera automatically sets the optimal shooting settings to produce natural skin tones. Landscape + Portrait. Suitable for taking photos of both your subject and the landscape. This setting allows both the foreground subject and background landscape to be in focus. Landscape. Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting settings to produce vivid blues and greens. Night and Portrait. Suitable for taking photos of your subject in the evening or at night. Since the shutter speed is slow, it is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Night Scene. Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting settings. If you use the flash, you can take pictures of both foreground subjects and the background. It is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Sports. Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Self Portrait. Enables you to take a picture of yourself while holding the camera. Point the lens toward yourself and the focus will be locked on you. The camera automatically sets the optimal shooting settings. The zoom is fixed in the wide position and cannot be changed. Movie Mode. Enables you to take a QuickTime movie.
Shooting modes
What is the best situation to use each of the shooting modes? The shooting modes are described as follows: Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
