Proform Crosswalk 500 Treadmill Logo
J
Julie Megson Posted on Jul 19, 2015
Where is the fuse I need to change, and how do I reset the treadmill?
I only have reset button on console,
My Z100 Tredmill screen will not reset or respond when any button is pushed on the console. The fuse on the board is good. The outlet is properly grounded. Need Help
Safety key is installed? No response from key presses usually indicates a "halt"state for the upper control "brains" like when the safety key is pulled. You can also try jatinah electronics for further help.
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
1helpful
Unit immoblize
reset the machine follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Mohamed1324
reset the machine use the small button to the side of power button and proceed according. God bless you
    • 3
    • 4
    • 2
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
4helpful
2answers
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
I cannot see You Tube on my I Pad
reset the system and try again.God bless you
    • 1
    • 3
    • 4
    • 2
Factory reset code
follow this instruction and reset. God bless you
need replacing, or move on to the next step.
  • 2
    console. Usually the button is large enough to trigger with a pencil
    treadmill.
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    Top Proform Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    john h
    Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
