). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Hi, 3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering. Hope this will help. Thanks.
Hi, It seems lamp in tv is dead and need to be replaced. Lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp for good picture. Thanks.
The problems ur tv having is also parts of the tv Convergence board are dead,but it is totally dead to causes this problems,if convergence board it still have some functions left.Tv will only have colors R,G,B will mis alignments,have colors shadows pictures and 3D pictures look alike,but convergence board are not getting any voltages at all that why u just hearing faint chirping noises that it.The tv convergence board,must require to changes 2 STK convergence ICS and some or all of it resistors too.For the covergence board have fully functions again to solved this problems.The shop will cost u like $300-350 for parts and labors.
Hi, If
Sony KF-60WE610 does not show any Red blinking light then it is Lamp
that need to be replaced because existing lamp has reached to end of its
life but still not dead nor broken and causing problem. If lamp got dead or broken, tv will show you Lamp light blinking. Replace lamp in tv to solve its problem. Hope these info will help you. Please buy Sony original lamp for good picture in tv. Let me know if you have any question. Thanks.
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Please check Lamp in TV that seems broken and causing red light bliknking on TV front, if it is Sony KDF-60XS955
If model is different, please mention it so to provide you proper helpful info.
Let me know if you need further info.
Thanks.
Assuming this is a TV with a picture tube and not plasma or LCD; I'm
afraid that your picture tube is dying on you one electron gun at a
time. From what you said your green electron gun is almost totally dead
and the two remaining blue & green guns aren't far behind.
Eventually you'll have no picture at all and I would estimate that to
be about 6 more months but whatever the time eventually it will go
totally black. These blackout periods will get longer and longer. The
only way to fix your problem is a new picture tube but my will probably
find it less expensive to just get a brand new TV set.
The set needs professional help,base in the description it seems it suffer a cascade power supply fairlure and it might take a few parts the get it repaired.Get an estimate to decide for a replacement.
