Samsung LN-T4665F 46 in. LCD Television Logo
m
mark manning Posted on Jul 21, 2015
How to fix
Disortion at bottom of screen when tv is fisrt turned on
When tv turns on the picture is disorted
if picture is 3d looking with colors skewed etc it is convergence--tell me as much as possible as if model listed is correct I know it well.
Mitsubishi vs55601 big screen tv. The proplem is when I turn it on I hear the click and a light flash on the screen but then it click rigt off. How do I fix this problem
It is an internal problem. In my opinion, i wouldnt handle this specific problem myself, but take it to a tv repair specialist. Fisrt, i would follow the trouble shooting manual, then all customer support.
Faulty picture which corrects itself after a few minutes.
Due to persistent on/off some components inside the TV might have become faulty, leaky. It can also be due to lose contacts. This might need attention by a qualified service technician.
Line Of Distortion Along The Bottom of an Em20 Burned Disc
It's possible there is either a codec problem with your computer player. I would recommend trying a player such as VLC Media Player, to see if that works. If that isn't it, what kind of TV's are you watching the video on? Are they "tubed" or flat screen? If they are tubed, you wouldn't be able to see the line at the bottom like you do when you play the video on the computer.
Picture is out of synch so in parts of the screen it looks disort
Well you can do it yourself if you have experince unsoldering and soldering.. change convergence amplifiers .. look for 2 parts with STK392-XXX .. depending on model number the 3 xxx will be the last 3 digits on that part
When u turn it on the screen goes blurry and disorted or it wont even display on the screen
This could mainly be that your scart lead could be loose at the tv end or it is loose at the console end, also see of the disc is not smudged or scracth sometimes this is a cause, it may be your tv is broken instead of the console, if it is a gameboy you may have broke a pixel line.
2answers
Color disortion
colors all messed up, looks like 3-D ??   convergence amps and possible a few resistors are bad
Horizonal problem
Practice visual acuity technique! Examine chassis,solder any/all bad connects,re-assemble,try again.If that does not do it,you might have a small break in pcb==gently flex board,try to isolate area.Above all else,do no harm!!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
